JF1081's avatar
JF1081
AC1750 Connect to Wireless AP
In the router setup if I go to Advanced > Administration > Wireless AP it looks like I can connect the router to a another network wirelessly. The help on that page says,
"View the wireless access points (APs) that are broadcasting wireless networks in your area. For each wireless network, the security level and the signal strength are displayed. To join a network, select it and enter its password if prompted."
However, I cannot seem to select a network. Clicking on a listed network does nothing. Is there something I'm missing? I have a newer moidem/router combo so I was hoping to use this one to get a better signal on the other side of the house and plug some devices directly into it (like a network bridge).
Is what I am looking to do possible with the C6300?
If not, what is that area of the the setup supposed to do?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello JF1081
    That page is a little confusing it can not do what you want all that page does is shows other networks in the area.
    DarrenM
