aravind_eee203
Jan 23, 2020Guide
AC1750 Netgear C6300 cable modem is intermittently working
Hi, my AC1750 Netgear C6300 cable modem is intermittently working. Sometime low band works, sometimes high band works and sometimes both seems to be down but lights on the modem are solid at all time...
Jan 24, 2020Guru - Experienced User
Try a factory reset and setup from scratch.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- aravind_eee203Jan 24, 2020Guide
There are too many wi-fi neighbours, but i never faced this problem until recently though i own this modem for couple of years. I tried updating the channels to as you suggested on both bands. If this doesn't solve the problem then i will try to do factory reset. I am skeptical about factory reset since that will leave me with connecting all the devices at home again. I will keep you posted on the status in a day
- FURRYe38Jan 24, 2020Guru - Experienced User
If you have too many wifi nieghbors, you could be in a wifi congested area. Try turning down the power output of the wifi radios from 100% to 75 or 50%...Maybe found under Advanced Tab/Advanced Settings/Wireless Settings
