Prestopopper
Jul 17, 2019Aspirant
AC1750 Netgear C6300 cable modem no internet light
Good afternoon, I have a Netgear C6300 cable modem. We went to bed last night and everything is working fine. This morning when we woke up, the internet light is not light and the upload button i...
- Jul 17, 2019
Was a factory reset on the C modem performed while connected to the coax or disconnected from the coax to see if the modem could be setup from scratch at it's set up wizard web page with a wire connected PC? If this fails, maybe time for a new modem.
Jul 17, 2019Guru - Experienced User
- PrestopopperJul 17, 2019AspirantI did a factory reset and everything seemed fine and then it went back to connecting then losing the connection.
The internet light is at least flashing now and it went out.- PrestopopperJul 17, 2019AspirantVictory, the second factory reboot worked!
- FURRYe38Jul 18, 2019Guru - Experienced User
Yay. Glad it's working now. Mark your thread as solved.
Enjoy. :smileywink:
