andy792
Jul 28, 2017Tutor
AC1750 router/modem won't show up on network list
I don't know if anyone else has had this issue. My wifi has been working correctly and last night, my router just disappeared from the network list. I thought my ISP was having problems so I didn't t...
michaelkenward
Jul 29, 2017Guru - Experienced User
Which hardware are we talking about? AC1750 isn't a Netgear model number. It could be a router, modem or cable modem.
andy792 wrote:My wifi has been working correctly and last night, my router just disappeared from the network list.
Where is this list? Wifi sources?
If the Internet goes off, it will show in the lights on whatever device we are talking about here.
- andy792Jul 29, 2017Tutor
Sorry about that. It's a c6300, so it's a modem/router. Well the list is what shows up on your computer when you try to connect to the wifi. Like when you click on the wifi signal on the bottom right.
- michaelkenwardJul 29, 2017Guru - Experienced User
OK. It can't see the wifi.
I asked because there are various places where things appear on the network, as wired or wireless devices.
I assume that this bit refers to Windows.
Well the list is what shows up on your computer when you try to connect to the wifi. Like when you click on the wifi signal on the bottom right.If so, the problem could be with Windows rather than the wifi from the modem router.
When the network disappears, do you still see the wifi LEDs on the c6300?
If you haven't found it already, the manual is here:
>>>> C6300 | Product | Support | NETGEAR <<<<
It looks like yoiu have the latest firmware:
What’s the latest firmware version of my NETGEAR cable modem or modem router?
As you say, even if the Internet died, you should still see the wifi.
When you say support told you to reset the thing, is that ISP support or Netgear? Did that reset include factory reset?
Well I can't see the network on any of my devices, such as my iPhone or my PS4. It just disappears, so I don't think it's an issue with my Windows laptop. The lights are on when it disappears. Netgear support told me to press and hold the reset button on the router so I'm not sure if that is a factory reset.
