John00
Jun 15, 2019Aspirant
AC1750 Smart WiFi Router(R6700v3) - Port Forwarding Not Working
For the AC1750 Smart WiFi Router(R6700v3) Port forwarding is still not working. I wish to create an open port to run a game from my computer. Application: Fantasy Grounds Port: 1802 Operat...
John00
Thank you for your reply and time.
Firmware Version: V1.0.3.66_10.0.50
Path: Dell (Alienware) Laptop Wireles > Router > Netgear CabLEModem CM1000 > Coaxial Cable - just one router
WAN/Internet (Advanced > Setup > Internet Setup):
Internet IP Address: Get Dynamically from ISP - Selected
Down further on the screen and unchecked:
Use Static IP Address: IP Address: 73.50.200.XXX ( matches )
antinode
Jun 15, 2019Guru
That looks good. Why your R6700v3 is using its alternate LAN subnet
("10.0.0.*") instead of its usual default ("192.168.1.*") remains a
mystery, but that's not fatal in itself.
The usual problems with this stuff are:
1. Wrong external IP address (different from the port-forwarding
router's WAN/Internet IP address). (An intermediate NAT router, for
example, could cause this.)
2. Bad port-forwarding rule (wrong port(s), wrong target address --
including a wandering target).
3. Server not listening on the port-forwarding target system.
4. External influences: ISP blocking, other firewalls, ...
You seem to have eliminated "1". So long as the target/server system
stays at "10.0.0.10", "2" should be ok. (An address reservation on the
R6700v3 for that system would be a good idea.)
> With the "Fantasy Grounds" application running...
That should cover "3", but an actual test would be reassuring. Can
you connect to the (game) server from some other (game client) system on
your LAN using the LAN IP address of the server (10.0.0.10:1802)? If
not, then port forwarding won't enable a connection from the outside
world.
If the router feature called "NAT loopback" is working on your
R6700v3 (which it should be), then you should also be able to connect to
the (game) server from some other (game client) system on your LAN using
the WAN/Internet IP address of the server (73.50.200.XXX:1802).
If all that works, then you get down to "4".
> Exception made in Windows Defender Firewall: (see attachment)
Does Windows know that "Fantasy Grounds" means port 1802?
Presumably, Windows thinks of your R6700v3 as a Private connection, so
Profile:All should be more permissive than you need. But that's only a
security risk, not something which would stop function.
If local access to "73.50.200.XXX:1802" works, but outside-world
access fails, then you may need to ask your ISP about it.
Or, of course, the R6700v3 firmware could be defective, but I don't
recall seeing oodles of similar reports for that model, which I'd expect
if it had such a defect.
