Scott5485
Jun 08, 2023Aspirant
AC1750 WiFi Cable Modem Router (C6300v2)
I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a s...
Kitsap
Jun 08, 2023Master
Scott5485 wrote:I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
What device are you using to check your throughput? Laptop, desktop, phone, etc.?
How is it connected to your C6300v2, via Wi-Fi or via Ethernet?
What application are you using to check your throughput? Recommend the stand alone installable application from Ookla, it is available free in the play store for all devices.
Normally your device would be discussed in the cable modem community here:
https://community.netgear.com/t5/Cable-Modems-Gateways/bd-p/home-cable-modems-routers
A moderator may move this discussion.
Scott5485
Jun 09, 2023Aspirant
I'm using a desktop to check. It is hardwired to modem/router. I used spectrum speed check to verify speed.
- Scott5485Jun 09, 2023Aspirant
I have Spectrum. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
- KitsapJun 09, 2023Master
Scott5485 wrote:I have Spectrum. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
What operating system are you running on your desktop computer?
Have you checked to see if your drivers for the Ethernet port are up to date?
Make sure you have good quality Ethernet cable between your computer and your R6300v2.
For consistency, you need to install the Ookla stand alone application for throughput testing. It does not use a web browser to get in the way.
- Scott5485Jul 05, 2023Aspirant
Can open app. Say no wi-fi. I go to play and download app as instructed. Say can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software.
- KitsapJul 06, 2023Master
Scott5485 wrote:Can open app. Say no wi-fi. I go to play and download app as instructed. Say can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software.
Difficult to decipher and I do not understand what you are trying to say. Complete sentences please.
Above statement is inconsistent with your statement about using a desktop computer hardwired to your router.
