Scott5485
Jun 08, 2023Aspirant
AC1750 WiFi Cable Modem Router (C6300v2)
I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a s...
Scott5485
Jun 09, 2023Aspirant
I'm using a desktop to check. It is hardwired to modem/router. I used spectrum speed check to verify speed.
Scott5485
I have Spectrum. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
- KitsapJun 09, 2023Master
Scott5485 wrote:I have Spectrum. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
What operating system are you running on your desktop computer?
Have you checked to see if your drivers for the Ethernet port are up to date?
Make sure you have good quality Ethernet cable between your computer and your R6300v2.
For consistency, you need to install the Ookla stand alone application for throughput testing. It does not use a web browser to get in the way.
- Scott5485Jul 05, 2023Aspirant
Can open app. Say no wi-fi. I go to play and download app as instructed. Say can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software.
- KitsapJul 06, 2023Master
Scott5485 wrote:Can open app. Say no wi-fi. I go to play and download app as instructed. Say can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software.
Difficult to decipher and I do not understand what you are trying to say. Complete sentences please.
Above statement is inconsistent with your statement about using a desktop computer hardwired to your router.
- Scott5485Jul 09, 2023Aspirant
Can't open app. Says no wi-fi. I go to play and download app as instructed. Says can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software. Please review attached screen shot attached.
