Scott5485
Jun 09, 2023Aspirant
AC1750 WiFi Cable Modem Router (C6300v2)
I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a s...
Kitsap
Jul 09, 2023Master
Scott5485 wrote:App connected previously. ?App supported.
Completely uninstall the mobile application and all of the data associated with it.
Reinstall and configure the mobile application from scratch.
Have you registered your router at netgear.com with a MyNETGEAR account?
Scott5485
Jul 09, 2023Aspirant
Yes,registered. Out of warranty.
- KitsapJul 09, 2023Master
Scott5485 wrote:Yes,registered. Out of warranty.
Warranty does not have anything to do with the question. When you sign in to your MyNETGEAR account, your C6300v2 should show up on your products list. Usually the Nighthawk application asks you for your MyNETGEAR account user name and password during install.
- Scott5485Jul 10, 2023Aspirant
I had to sign-in when I reloaded app?
