lildestiny
Sep 05, 2020Aspirant
AC1750 WIFI CABLE MODEM ROUTER DROPPING WIFI CONNECTION CONSTANTLY
Hello, For the past several weeks my modem router AC1750 has been dropping wifi connection. It happens several times a day, the connection blinks out and comes back or drops for several minutes....
lildestiny
Sep 06, 2020Aspirant
I have no idea what channels Im using. Where would I see this and make these changes? Im not sure where to login to gain access to the modem. Yes my computer can see 3 wifi networks from my neighbors, all very weak signals.
Sep 06, 2020Guru - Experienced User
If you have the C6300, try factory resetting it. push and hold reset for 7-15 seconds while its powered on.
- lildestinySep 06, 2020Aspirant
Thanks. Ill give that a try. Any steps on what to do after I reset it?
- plemansSep 07, 2020Guru - Experienced User
Install it?
then you can try changing the wireless channels if its still dropping.
- lildestinySep 12, 2020AspirantSorry I did not receive any notifications saying I received a reply.
How do I install it if I'm unable to sign into the router with the websites? I found a YouTube video to show how to factory reset but the website it says to go to "routerlogin.net" doesn't load anything. Will I be able to access this website once I reset? Do I need to call my ISP when/after I do this?
