APCT's avatar
APCT
Follower
Oct 08, 2024
AC1750 WiFi Cable Modem Router Model C6300v2
Did a factory reset so I could put a new password in. My desktop is fine. WiFi is sending out a dead carrier. A device can connect
to the router. The device has no internet connection.
1 Reply
  • plemans's avatar
    APCT wrote:
    Did a factory reset so I could put a new password in.----like wifi password? or password to access the device?  My desktop is fine.-----is that wired in? Wireless?  WiFi is sending out a dead carrier. A device can connect
    to the router. The device has no internet connection.-----you changed the wifi password or login? Did you try deleting the deleting the network connection from the device? Try rebooting the router? Checking to see if the router is provisioned?
