mustanggal24
Jan 10, 2024Aspirant
AC1750 WiFi Cable Modem Router
Hi, This is my first post so I am not sure I am doing this correctly. We had a couple power surges and then our power went out last night. Now my wifi will not stay connected. All lights are on...
Jan 10, 2024Guru - Experienced User
Pressing the reset button for 10 seonds then after the modem reboots, setup the modem again with a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
mustanggal24
Can I do a factory reset while I am logged into the modem through the routerlogin page?
- FURRYe38Jan 10, 2024Guru - Experienced User
- mustanggal24Jan 10, 2024Aspirant
That seems to have fixed the issue. Thank you so much!!!!!!!!!!!!!
