Sanjayuce
Oct 14, 2023Aspirant
AC1750 WiFi is not broadcasting
Hi, I have AC1750 WiFi Cable Modem Router (C6300v2) All lights are glowing but not broadcasting wifi. Not seeing in any devices. Tried power recycle, reset but no luck. internet is working if yo...
Sanjayuce
Thanks, the link 192.168.0.1 worked
I reseted password and Enable SSID Broadcast enabled.
Not sure why wifi is not broadcasting.
Netgear support team mentioned hardware is fine.
Thanks
Oct 15, 2023Guru - Experienced User
did you push and hold the wifi on/off button for at least 2 seconds?
