mmfallon
Jan 30, 2022Aspirant
AC1900 - Model C7000v2 Router will give laptops internet access but not mobile devices
yesterday, we had a power outage. When power came back on, laptops reconnected to the router. The phones - an iPhone and an Android - can't connect to the internet. I disconnected ("forget") on the a...
Jan 30, 2022Guru - Experienced User
have you tried simply factory resetting the router and reinstalling it?
mmfallon
Jan 31, 2022Aspirant
Yes, I did that and nothing improved.
- plemansJan 31, 2022Guru - Experienced User
Have you tried changing the wifi ssid and password to something new?
- mmfallonJan 31, 2022Aspirant
Found out that the issues went beyond my phones. Couldn't connect to certain websites, access my email with Outlook, and use certain apps - like Teams.
Reset again through Xfinity, but no luck with that.
Hauled out the orginal modem router, and that is working fine. (File under "Why are you keeping the old router?"
I appreciate you taking the time to respond. Thank you.
