mmfallon
Jan 30, 2022Aspirant
AC1900 - Model C7000v2 Router will give laptops internet access but not mobile devices
yesterday, we had a power outage. When power came back on, laptops reconnected to the router. The phones - an iPhone and an Android - can't connect to the internet. I disconnected ("forget") on the a...
Jan 31, 2022Guru - Experienced User
For iPhones did you turn OFF "WiFI Private Address" feature on the phone?
mmfallon
Jan 31, 2022Aspirant
Thank you for the input. I ended up replacing the router as other apps stopped working.
- FURRYe38Jan 31, 2022Guru - Experienced User
đ
Be aware that Apples new WiFi Privacy Address feature is causing some problems. Something you can disable while at home. If you travel, enable it then.
Good Luck.
