dolo264's avatar
dolo264
Follower
Aug 16, 2019
AC1900 C6300 firewall settings
My car cannot connect to the Wi-Fi via the internet connection. Cox cable doesn't know what I'm talking about and suggested contacting Netgear. Tesla said that the settings on the router sometimes do...
  • FURRYe38's avatar
    Aug 17, 2019
    What is the Mfr and model# of the extender in the garage? Turn OFF the extender and see if the car will connect.
    What security modes are you using? Try WPA and TPIK or as a quick test, set all WPA to disable. See if the car will connect then. IF so, Re-enable WPA2 and AES only on the modems wifi.
