hunterwalton97's avatar
Dec 31, 2019
AC1900 (C7000) downstream blinking
I recently got Spectrum cable internet and a Netgear C7000 modem/router. At first, speeds were 100mbps+, but now they’re less than 30mbps and the downstream light is constantly blinking green. Any help?
1 Reply
  • plemans's avatar
    It usually means that the downstream channels aren't all locked or its searching to lock them.
    If you pull up your modem connections page and take a screen snip, it'll help.
    Also if you have any splitters, attenuators, or amplifiers on your coax line, I'd recommend removing them.
