PQM
May 04, 2017Follower
AC1900 C7000 LAN ports dead
Was streaming TV & working earlier when all of my connections dropped (both WiFi & LAN). I assumed either the modem reset randomly or my service (WOW cable internet) dropped. Everything came back onl...
ahamka
Jun 22, 2017Aspirant
My LAN Ports just stopped working w/o cause. I do see there is a new firmware update on my router (V1.01.23) , I currently have V1.01.15 - Could this be the issue or is the device defective?
- DarrenMJun 26, 2017Sr. NETGEAR Moderator
Hello ahamka
The firmware shouldn't be the issue with the ports have you tried a factory reset?
DarrenM
- bvardemanAug 01, 2017Initiate
This just happened to my router today as well. Has anyone found a solution to this?
Everything was working fine, then the LAN outlets all stopped working. My wifi still works fine. I have factory reset the router with no luck.
- vkdeltaAug 02, 2017NETGEAR Employee Retired
if you connect something, does it link? do you get link LEDs?
