Surfster
Oct 24, 2022Follower
ac1900 C7000 v2 Setup options with another modem/router
I am wondering how to use an AC1900 C700v2 as an addon router with my home network setup. Verizon Fios comes into the house and goes to a G3100 router via an ethernet cable. I am interested in creating a separate network using the AC1900 or using the AC1900 to extend the current network. How would I go about each of these? I also have coax in the house. is it possible to use the AC1900 to connect devices utilizing moca adaptors?
Thank you
C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router
1 Reply
The C7000 is a cable modem/router. It doesn't have a standalone router function.
You can try and get it running as a form of AP but not sure if it'll work with that device.
