Kid_90
Jan 14, 2020Tutor
AC1900 C7000 wireless connection freezes
I'm using the AC1900 C7000 as a Wireless Access Point behind an ATT modem router. I have wireless access through the AC1900, but every now and then the connection stalls. For instance if my phon...
antinode
Jan 14, 2020Guru
> modem router.
How, exactly, did you configure the C7000 for that purpose? (It's
not a supported mode of operation, and may be harder than you think.)
Possibly interesting:
https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300-as-WAP, but the steps are about the same for
any other router (any make/model) which lacks a one-step WAP option.
> Anyone knows how to resolve this?
I don't know what's causing it. Is e-mail the only service with a
problem? Web browsing, for example, still works?
Kid_90
Jan 14, 2020Tutor
Browser also loses connection.
I configured the wireless networks on the 2 routers to use 2 non-overlapping channels and will see if that resolves the issue. One router configured to use channel 11 and the other one is set to use channel 6 (this is for the 2.4 GHz)
Configured 2 different channels for 5 GHz network as well.
- Kid_90Jan 15, 2020Tutor
Still the same issue. Woke up this morning and connection to the Internet was down. Disconnected the wireless connection from my laptop and reconnected again... can access the Internet.
Still no clue why this is happening.
