Serix13
Mar 08, 2022Aspirant
AC1900 C7000v2 Nighthawk - Random Packet Loss Started out of nowhere
Like the title says, just started randomly happening 2 days ago to me, nothing changed in regards to my settings or service provider. Called and checked with them and they said everything was good o...
Mar 08, 2022Guru - Experienced User
Your power levels are out of spec, you have unlocked channels, and you have errors in the line.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
If all that doesn't help, then the isp needs to check the line.
Serix13
Mar 09, 2022Aspirant
Ended up buying a new cable and the modem is connected directly without any other adapters inbetween
https://imgur.com/oWVDYHG
Still not having any luck yet. Still just trying to do everything I can on my end and im contacting my ISP here in a bit.
- plemansMar 09, 2022Guru - Experienced User
tons of errors in the line.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.If that doesn't help, the isp needs to check the line.
