jcabal
Apr 20, 2021Aspirant
AC1900 C7000V2 power light red
I had a brief power outage last night and now the modem/router will not power up. Power light is red, and I have unplugged from outlet, waited a couple of minutes and plugged back in, but no change. ...
Apr 20, 2021Guru - Experienced User
could be.
what you can try.
disconnect the coax from the c7000. Then while the c7000 is powered on, push and hold reset for 30 seconds, unplug power while still holding reset for another 30 seconds, then power it back on while still holding reset for 30 seconds.
jcabal
Just tried that, but unfortunately no change. Thank you for responding, though.
