Ron23
Dec 15, 2023Tutor
AC1900 C7000v2-routerlogin won't launch
I launch my browser (chrome or edge) and enter: routerlogin.net or the IP address of the router and the prompt to login doesn't come up using my new machine. It does launch using an old machine. I d...
- Dec 28, 2023
I disabled my VPN in my new machine and now the window to login to my router pops-up. I put in my credentials and it allows me to login but all I see is a white blank screen.
Using my older machine continues to work fine.
It seems I'm getting closer after implementing some of your ideas but I'm not there yet. Please continue to send me suggestions.
Thanks.
schumaku
Dec 16, 2023Guru - Experienced User
Some overly secured Web browsers or security plugins might prohibit the access to simple devices like routers making use of the basic auth for the login if no HTTPS is available.
Ron23
Dec 28, 2023Tutor
Thanks.
- Ron23Dec 28, 2023Tutor
I have found a solution. I'm even using my VPN.
I'm using Google Chrome. I went to Settings -> Privacy and security -> pop-ups and redirects.
Then under the setting "Allowed to send pop-ups and use redirects" I added: routerlogin.net
Thank you for all the suggestions. They helped.
