anakin827
Nov 19, 2018Aspirant
AC1900 C7100V Static Routes
I have the AC1900 Nighthawk Modem/Router and trying to understand if I can set up a static route in this particular model?
Nodism1125
Nov 19, 2018NETGEAR Expert
Hi anakin827,
Static Routes not supported for C7100V.
- anakin827Nov 19, 2018Aspirant
Well that stinks. Any other ways to possibly do it since this device cannot support?
- antinodeNov 19, 2018Guru
> Well that stinks. [...]
I agree.
> [...] Any other ways to possibly do it since this device cannot
> support?
Use another device? Use the C7100V as a modem-only, and get a
competent router to use as a router?
Why do you need static routes? (I use them on my D7000 to get to
odd-ball devices/subnets like a SIMH-emulated VAX, or an old Raspberry
Pi Zero which has only USB networking, or the second Ethernet port on a
Mac Pro, or the like.)- anakin827Nov 19, 2018Aspirant
Need a static route for a VPN I'm configuring that would give out IP addresses in a different IP address/subnet range.
