anakin827
Nov 19, 2018Aspirant
AC1900 C7100V Static Routes
I have the AC1900 Nighthawk Modem/Router and trying to understand if I can set up a static route in this particular model?
Nodism1125
Nov 19, 2018NETGEAR Expert
Hi anakin827,
Static Routes not supported for C7100V.
anakin827
Well that stinks. Any other ways to possibly do it since this device cannot support?
- antinodeNov 19, 2018Guru
> Well that stinks. [...]
I agree.
> [...] Any other ways to possibly do it since this device cannot
> support?
Use another device? Use the C7100V as a modem-only, and get a
competent router to use as a router?
Why do you need static routes? (I use them on my D7000 to get to
odd-ball devices/subnets like a SIMH-emulated VAX, or an old Raspberry
Pi Zero which has only USB networking, or the second Ethernet port on a
Mac Pro, or the like.)- anakin827Nov 19, 2018Aspirant
Need a static route for a VPN I'm configuring that would give out IP addresses in a different IP address/subnet range.
