mjacob98
Jun 15, 2022Aspirant
AC1900 cable modem router
HI all, I live in a 4-story home and have the AC 1900 modem/router on the 2nd floor. Certain areas have slow wifi speeds and I am trying to figure out the best way to increase wifi on the other f...
Jun 16, 2022Guru - Experienced User
What is the size of the home? Sq feet?
May need a wifi extender to add...
- mjacob98Jun 16, 2022Aspirant
It's about 2000 sqft. Multi-level home, 4 stories. Will an extender work? Or should I buy an Orbi router with 2 satellites. I wasn't sure if that was overkill. Thanks in advance.
