bob1951
Dec 19, 2024Initiate
AC1900 Model: C7000v2 Is it possible to shut down the 5GHz side of the router.
My Arlo security cameras need to initialize on the 2.4Ghz band. Is there a way to shut down the 5GHz band to keep it from interfering? Once I'm connected to the 2.4GHz band, I can switch to the 5GH...
- Dec 20, 2024
That would make a difference 🙂
Might mark it solved so others aren't still trying to fix it
Dec 20, 2024Guru - Experienced User
You don't have to "shut down" the 5ghz.
I have quite a few arlo camera. Both base station based and wifi based.
And none of them have needed the 5ghz disabled to function or setup.
What arlo camera do you have?
Did you check with arlo?
are you on the latest arlo app?
