mgftp
Jan 01, 2021Tutor
AC1900 Modem Router C7000 Unknown Wired Device Showing under Attached Devices
Hi, I had to reset my router due to a power surge. After setup I noticed that it was showing two wired devices connected when I only had one connected. I ended up blocking this device with the Devic...
Jan 03, 2021Guru - Experienced User
Dies connect all wired devices accept for 1 wired PC to see if the extra phantom device appears after you reboot the modem.
Try a factory reset and setuo from scratch as well with with 1 wired PC connected only and see.
mgftp wrote:Hi, I had to reset my router due to a power surge. After setup I noticed that it was showing two wired devices connected when I only had one connected. I ended up blocking this device with the Device Name of "ICP" but am left wondering what it is? And how I can have 2 wired devices connected when I have only one ethernet cord coming out and going to one PC. Any insight would be appreciated. Thank you.
