Dslim1973
Apr 29, 2020Aspirant
AC1900 WiFi Cable Modem Router Model C7000v2 keeps disconnecting
I just purchasd the cable modem router. The problem I am having is that it keeps disconnecting? Is there a fix for this? Please advise
Disconnecting? How so?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? - plemansGuru - Experienced User
Whats disconnecting? the wireless? wired devices? is it saying connected but no internet?
Just saying its disconnecting doesn't tell us much. Please go into more details.
Also, log into the device and take a screen snip of the cable connections page and the logs. this shows the connection back to the ISP.
