Analog_DSN
Sep 28, 2021Aspirant
AC2300 and CM1000
Having trouble with my internet service dropping out daily, mostly when in a meeting, Zoom, Teams, etc. Seems unrelated to applications running on my PC. There are 2 users on this system. Seems u...
Sep 28, 2021Guru - Experienced User
AC2300 WIFI Router is not a model # or brand name.
What brand and model # router do you have connected to the modem?
Disconnect the wifi router and connect up 1 wired PC to the modem and see if problems are seen.
- Analog_DSNSep 28, 2021Aspirant
Thanks for the reply. You are correct. The WIFI Router Model is R7000P. The Modem is CM1000.
- plemansSep 28, 2021Guru - Experienced User
You said drops still happen when directly connected to the cm1000?
Do you have a screensnip of the cable connections page and the event logs? That helps a lot more than 1 line.
