trinDFW
Nov 16, 2020Follower
AC3200 WiFi Cable Modem Router Model C7800 - use as AP mode only
I had fiber internet installed today. The service provides its own router (with ONT connection) and wifi. However, the wifi signal is moderate at best. I'd like to use my netgear equipment for wifi i...
awning-sector
Jul 05, 2022Aspirant
It should be noted that this guide needs to be followed exactly!
If you don't restart between setting static IP and disabling DHCP, it wont work.
This troubled me for many hours.
You might try the procedure at:
- FURRYe38Jul 06, 2022Guru - Experienced User
If you set the static IP and then disable DHCP server all in one application, does work. Did for me when I check on my C7800...
