NetJRB
Mar 04, 2016Aspirant
AC5300 Nighthawk X8 AC5300 Tri-Band WiFi Router - lack of STP protocol support for SONOS
I was reading the product manual for this router and found out it does not support STP (Spanning tree protocol) which is used by the SONOSNET network. I cannot plug in more than one speaker to my wi...
- Mar 05, 2016
Sorry....I meant to say NETGEAR tech support confirmed AC5300 lacks STP support.......
TheEther
Mar 04, 2016Guru
NetJRB wrote:Is an option to get around the lack of STP (Spaning Tree protocol) support on the router to get a managed switch from NETGEAR that supports STP? All the network traffic will go through the managed switch then to the router? Just wondering if this is a possibility?
I had to read up a bit on Sonos and their need for STP. I think the answer is, "Maybe." I think it will work if you insure that the Sonos devices are not connected to the router's Wi-Fi network. If you connect the Sonos to the router's Wi-Fi network, then the Sonos may try to over Wi-Fi through the router and you will lose the benefit of the managed switch. You may be able to set up the Sonos devices to use their own private, meshed Wi-Fi network to communicate amongst themselves. I'm not sure if this requires their Sonos Bridge or Boost.
I suggest you take your question over to the Sonos user forums (link). STP comes up quite frequently as a topic.
NetJRB
I did early on this morning and that was one of the options. With my old router I was able to have 4 speakers hardwired to the router through the ethernet ports through my house. The old router supported STP. When I connected my speakers yesterday to the new router I connected the same 4 speakers I had wired to the old router. This morning my internet connection - all computers - was looping due to a broadcast storm.
My options are either to wire only one SONOS speaker to the router. This will start SONOSNET in "Boost" mode and let all the other speakers go wirelessly. SONOSNET is a separate 2.4 GHZ wireless network that does not broadcast the network SSID so it does not uses the router 2.4 GHZ wireless network.
For reliability it is better to have more SONOS components wired to the router but not having STP protocol support on the router creates an issue when more than one component is wired....I just need to ensure that an STP capable swtch will be a workaround for this problem and a switch that will be compatible with this router.
- TheEtherMar 04, 2016Guru
Do you still have your old router? You can use it in place of the managed switch to test the hypothesis. Disable the DHCP server on the old router, and assign the LAN side of the old router with an IP address that won't conflict with any of your devices. Connect a LAN (not WAN) port on the old router to your new router. Plug your Sonos devices into the old router and test.
- NetJRBMar 05, 2016Aspirant
The issue is with the Linksys SE4008 network switch. I powered all 15 SONOS players last night and this time only one is wired to the ethernet port. I had no network issues at all this morning. Linksys tech support confirmed the router lacks STP support. The SONOS support forum had a long thread regarding STP and basically most switches are able to handle it. There is a switch from NETGEAR that will work with SONOS and that is GS208 (8 port switch).....I am going to replace 3 of my Linksys switches that handle the bulk of the network traffic in my house with this switch....all the SONOS players will connect to the router via GS208 and that will enable me to wire more speakers to the wired network if I have to.
