gnanard
Jan 14, 2022Aspirant
acces plex+dlma
Bonjour j'ais installe un hub GS308T pour avoir l'agregation sur mon synology ds220+ mon probleme c'est que depuis je ne voies plus ma biblioteque de films dans plex et je n'ais plus acces egalem...
Jan 14, 2022Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with Switch products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/bd-p/business-smart-plus-click-switches
Thank you.
- gnanardJan 14, 2022Aspirant
Hello
I installed a GS308T hub to have aggregation on my synology ds220+
my problem is that since then I no longer see my library of films in plex
and I no longer have access also in DLMA
this on my lg tv
thank you for your help because it must be a configuration problem because when I reconnect my old ethernet hub I have no worries but it does not integrate
thanks in advance
