Anthonycastle's avatar
Feb 07, 2023
Access control on cax80
Access control list  can't  be edited,  can't manually  add mac addresses, and none of the buttons  add, edit  ,  don't work in any browser.
1 Reply
  • FURRYe38's avatar
    Is Armor or Smart Parental Controls enabled on the NH app? Disable these if they are in the app, then power off the modem for 1 minute then back ON.
    Try a different PC or web browser as well.
