n_wang
May 07, 2022Aspirant
Access My Router
I have a weird problem. I want to access my router C6300 (AC1750). However, the website "routerlogin.net" cannot be loaded. I have tried every possible way to solve it, using the ip address to log in, trying to access it through different browsers, etc. The website still cannot be opened even if the router has been factory reset. Anyone who has the same problem? Thanks ahead.
Try 192.168.0.1 or .1.1 or 192.168.100.1
Be sure to clear out all browser caches.
Try a different browser.If these fail, you'll need to factory reset and setup from scratch.
- n_wangAspirant
Thanks. But none of them works.
What happens when you try?
You provide no detail to go on. Statements like "none of them works" are llttle help.
Try answering the questions that Negear's forum suggests:
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
- Subject (Include model number and brief summary)
- Model (Recommended - Helps the community give the best answers)
- Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
How are you connecting to the router? Wired LAN? Wifi?
Anything else on the network?
