dsfyuri23
Oct 07, 2019Aspirant
Access point configuration in C6300
How to configure access point in my C6300?
Oct 07, 2019Guru - Experienced User
C series modems don't support AP modem. You can only run the modem in router mode or modem only mode.
antinode
Oct 07, 2019Guru
https://community.netgear.com/t5/x/x/m-p/1463500
> [...] You can only run the modem in router mode or modem only mode.
I doubt that.
> My Setup [...]
Still useless.
- BoilerPlateOct 08, 2019Apprentice
And you use of > [...] is completely even more useless. Really makes reading your replies hard for everyone and how you format your posts is useless as well. Also is your snide comments about how users post there questions.
If you don't like how users use there signature, don't look at it. It's not for you to look at or comment on. Users can use there signature how they want to. If you don't like it too bad, go else where. This is NetGears forum, if you don't like how they run it, make your own.
At least others are helping others out with there posts and getting results.
Be more supportive and less of a A$$ hat.
Nobody cares if your an old IT has been.
antinode wrote:> How to configure access point in my C6300?
> [...] You can only run the modem in router mode or modem only mode.I doubt that.
> My Setup [...]Still useless.
