whynotme
Jul 26, 2019Aspirant
Access Points not being assigned IP address
Tried to replace my Xfinity 1Gb gateway with this new CM1150V but none of my 3 access points are getting an ip address. I've tried it with a Netgear router AC1700 and 2 different Ruckus Wireless ap'...
antinode
Jul 26, 2019Guru
> Tried to replace my Xfinity 1Gb gateway with this new CM1150V [...]
Why? Was there some actual problem which you were trying to solve?
What, exactly, is your "my Xfinity 1Gb gateway"? If it's some kind
of (cable-TV-type) modem+router, and you replaced it with a simple
modem, then I'd expect many things not to work as before (if at all).
> [...] Something about this modem won't assign ip addresses to
> routers/access points. [...]
Yes. The fact that it's a modem, not a router with a DHCP server.
> [...] the ap's and Netgear router [...]
What, exactly, is your "Netgear router"? Is it configured as a
router, or as a wireless access point?
whynotme
Jul 28, 2019Aspirant
I was trying to replace my rented Xfinity modem with an owned device to remove the $13 modem rental fee. The Xfinity is model TG3482G. I was running in bridge mode, so the router function was turned off.
Can this modem not act as DHCP server?
- antinodeJul 28, 2019Guru
> I was trying to replace my rented Xfinity modem [...]
> [...] TG3482G [...]
An ARRIS TG3482G is a "gateway" (modem+router), not a simple modem.
> [...] I was running in bridge mode, so the router function was turned
> off. [...]If the router functions of the TG3482G were disabled, then I'd expect
its DHCP server to be disabled. If all you did was disable its
wireless-network radios, then its "router function" was not "turned
off".> Can this modem not act as DHCP server?
Generally, a _modem_ does not include a DHCP server. A _gateway_
(modem+router) or a _router_ will include a DHCP server. A Netgear
model "CMxxxx" is a modem, not a gateway, so no DHCP server. (Also, no
other router functions.)- whynotmeJul 30, 2019Aspirant
That explains it. How would the router actually get an ip address if not assigned by the modem? Why would anyone buy this modem if you can't directly connect a router to it?
- DarrenMJul 30, 2019Sr. NETGEAR Moderator
You need to connect a router to the CM1150V and then you can connect your APs to the router.
DarrenM
