jqhall63
Dec 15, 2016Aspirant
accessing 5g network on W7 system
I'm using an AC1750 wifi router. it works will with my w8 pc and my ios system devices. They can see both primary and guest networks and 5g and non-5g. However, on my w7 pc, it cannot find the 5g ...
ElaineM
Dec 16, 2016NETGEAR Employee Retired
Welcome to the community, jqhall63
What's the exact model number of your NETGEAR device?
On your Windows 7, can you the 2.4GHz signal? If you do, then your Windows 7 machine only supports 2.4GHz signal.
However, if it cannot find any other wireless network check if the wireless feature on that computer is turned on.
