CP1001
Sep 09, 2022Follower
Accessing CAX30 Router as Admin..
I used to be able to access my router with my pc via 192.168.1.1 or routerlogin.net. Those no longer work. Has Netgear changed something or might it be a Windows10 issue? Connecting with the Nigh...
Sep 09, 2022Guru - Experienced User
Try 192.168.100.1 as well?
Whos you ISP?
Have you tried a factory reset and setup from scratch? Press the reset button for 10 seconds.
