GSPRODUCT
Mar 21, 2019Aspirant
ACCESSING WNDR4300 FROM MY C3700
How do i access my NVR SURVEILLANCE SYSTEM,,,,, That is connected to my WNDR4300 router,,,,,,which is connected to my C3700 router/modem..... from my COMPUTER which is connected directctly to my ...
antinode
Mar 21, 2019Guru
"WNDR4300" or "WNDR4300v2"? Firmware version?
> [...] now I have 2 Networks and 2 routers.
Since you've replaced your old (unspecified) "my modem" with a
modem+router, the straightforward way would be to configure the WNDR4300
as a wireless access point, rather than as the full-function router it
currently is. That should eliminate your two-router problems. Visit
http://netgear.com/support , put in your (actual) model number, and look
for Documentation. Get the User Manual. Look for "Wireless AP".
GSPRODUCT
Its setup as a wireless access point. I have devices wired and wireless connected to it . They are able to access the internet . When i got the C3700 i simply unplugged my computer from the old router, plugged it up to the new C3700, set up the C3700 and then connnected the wndr4300v2 to it via the 2 yellow ports on the rearand it worked.
