GringiColombi
May 01, 2022Follower
Accidentally factory reset router and unable to to connect to app (C7000v2)
I was trying to reset my router by disconnecting the modem for 10 seconds then reconnecting how ever when I had seen that the lights were fine and it had indicated that the wifi was back up none of ...
May 01, 2022Guru - Experienced User
try using its ip address. 192.168.0.1
you'll need to go through the setup process if you haven't.
(if it asks you to use the app, there's a "i don't have a phone" link at the bottom of the page)
