tdiddy1226
Mar 21, 2016Aspirant
adding a 5GHz wifi router
can a 5GHz wifi router be added onto a c3000 through the network connection?
netwrks
Mar 21, 2016Master
It supports DHCP. If you have a spare port on the C3000, you should be good to go..
EDIT: Your new router would need to be configured in Access Point mode, prior to adding to the C3000.
- tdiddy1226Mar 21, 2016Aspirant
I just got the c3000 and also just got comcast. I cut the cord with cable and am just streaming now. I'm getting above the rated speed on wire but the wifi is dropping with 2 wireless devices streaming. They don't lag much but I do see a delay in loading. I think I'm just going to return the modem and go for the c3700 since it boasts simultaneous dual band 2.4 and 5.0.
- HiThere22Mar 21, 2016Star
The c3700 is known to have issues with Comcast due to the firmware they push, I would invest in a seperate modem and router seem to have more flexability with device like that
- tdiddy1226Mar 22, 2016Aspirant
I appreciate the feedback. I ended up returning the C3000 and purchasing an Arris SBG6700 AC. So far much more speed over wifi. I went from a marginal 12mbps up to 50+mbps!
