clinew0791
Mar 29, 2022Follower
adding a secondary modem router as a hotspot wirelessly connected to a primary modem router
adding a secondary modem router as a hotspot wirelessly connected to a primary modem router I would like to know if it is possible to configure the following. I have researched this and tried it...
Mar 29, 2022Guru - Experienced User
No. You didn't describe it the best.
You can have 2 modems from your isp but then you're paying for 2 internet services.
And neither of those devices is that high of performing.
I guess the real question is what are you trying to do?
Better coverage?
WAN failover? Load balancing?
