ambernicole's avatar
ambernicole
admin and pass
I can not retrieve my admin and password. I would like to email netgear if possible. Is there a contact email?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you talking about the login info to access the settings of your router?
    DarrenM
      • DarrenM's avatar
        DarrenM
        The easiest way to fix this is hold the reset button on the back of the modem for 10 seconds this will default it back to admin/password for the login but you will also lose all your settings and will have to set your wifi and other settings back up.
        DarrenM
