woody_weaver
Nov 20, 2023Follower
admin interface doesn't support https?
Device is a CM1000v2 cable modem; hardware 2.02 firmware V10.01.07 and seems to be current. I'm surprised that the admin interface is not TLS enabled, and that there is nothing listening on 443? ...
Oct 02, 2023Guru - Experienced User
Thats there "recommended" list.
Its still compatible and supported under the "Full List of Compatible Devices" list.
strykerzr350
Oct 02, 2023Guide
Sadly that means nothing to them, as far as they told me. The compatible and recommended list are completely different things. Until they add it to the recommended list, they wont support it by pushing firmware updates.
Netgear seems to get the short end of the stick when it comes to modems I have seen.
