Draxiumwulf
Jul 03, 2016Aspirant
Advice on proper hookup and settings for C3000, G5605 and multiple devices.
Due to a power surge on the cable network I had to buy a whole new setup. I purchased a C3000-100NAS with firmware V1.01.11 because it is a combo cable modem and router. However it only has two 10/10...
DarrenM
Jul 07, 2016Sr. NETGEAR Moderator
Hello Draxiumwulf
I would check a couple settings the first is under Advanced-Setup-LAN setup make sure use Gateway as DHCP server is checked and then under Advanced-Administration-Router mode make sure that is on yes.
DarrenM
- DraxiumwulfJul 13, 2016Aspirant
All set that way by default, But I unset them, saved and reset them and saved. Managed to get smart tv online but not xbox, even then things were real slow. Going to find different cables to try.
- DraxiumwulfJul 25, 2016Aspirant
Tried a few cables from c3000 to g5605. I also reset the modem/router, starting and restarting everything, I got functionality, but kind of unstable, occasionally get dropouts both on xbox360 , xbox one . Wi-FI seems weaker and seems to drop connections
