archerlady1's avatar
archerlady1
Follower
Nov 06, 2022
After network reset, am no longer able to connect Smart TV to router C6250
Purchased in 10/30/20. Netgear only supports up to 90 days, $50 for 2 yrs support now. Any chance this can be solved w/o going to Best Buy Geek Squad?
When I go to Router Login on my laptop, it asks for new password then doesn't proceed to next page. ???
  • What has that to do with the subject of your message?
    Connecting a smart TV to a router should not need you to go anywhere near routerlogin.net.
    It just hangs?
    Is this wired into the router or on wifi?
    Have you offered it a new password?
    Netgear is getting very dictatorial about passwords. It wants to force us to protect ourselves even when it is not needed.
    You reset the router. So feed it with a new password and see what happens.
  • archerlady1 wrote: Novitasphere Login
    Thanks a lot for the reply. I will try the suggested solution from your link.
  • michaelkenward's avatar
    michaelkenward
    It just hangs?
