Scumbus's avatar
Scumbus
Follower
Jan 08, 2020
All LED’s off except the Ethernet LED which is amber on my CM100 Modem
All of the LED’s on my CM1000 high speed modem, yet the Ethernet symbol is Amber. I have no clue how to fix this, I’ve never seen the problem before and my internet connection has ceased to work completely. My Netgear router seems to be doing fine other than the internet symbol is off which I’m assuming is the modem’s fault.
1 Reply
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Ethernet amber generally means your Ethernet is running 10/100 Mbps. you may want to check if your router has gigabit WAN port.
