Tex2000's avatar
Tex2000
Initiate
Jun 08, 2022
All LED’s off except the Ethernet LED which is amber on my CM100 Modem
I have the same issue.  Nothing is plugged into the CM1000 except for power.
  • FURRYe38's avatar
    What brand and model is the external wifi router connected to the modem?
    Factory reset the modem by pressing the reset button for 10 seconds then release?
    Have you pulled the power adapter for the modem for 30 seconds then back in with the ISP coax line and external router cable disconnected?
    Try a different power supply with same voltage and Amp specs?
    • Tex2000's avatar
      Tex2000
      Initiate
      I'm not connected to anything.  It does not seem to initialize correctly based on the LED sequence.  I am using the AC poser adapter provided with the unit.
