Shell770
Jul 23, 2016Initiate
Amazon Echo and Netgear C6300
Has anyone figured out how to get Amazon Echo working with the Netgear C6300? Specifically alarms and timers? I've disabled Port Scan and DoS Protection, and turned on Respond to Ping on Internet Po...
erin1954
Aug 05, 2016Aspirant
My Echo was connected to my C6300 fine up until 3 days ago. Now I can't get it to connect to it at all. I have reset the echo as well as the modem and still nothing. Any ideas on how to resolve the connection issue or what is causing the problem? Everything else has connected fine via wifi but the Echo.
DarrenM
Aug 05, 2016Sr. NETGEAR Moderator
Hello erin1954
You may want to try and switch the wireless channel on the modem see if then it will connect.
DarrenM
