Shell770
Jul 23, 2016Initiate
Amazon Echo and Netgear C6300
Has anyone figured out how to get Amazon Echo working with the Netgear C6300? Specifically alarms and timers? I've disabled Port Scan and DoS Protection, and turned on Respond to Ping on Internet Po...
Shell770
Aug 05, 2016Initiate
Hi All,
Thank you for your responses. Always nice when users help each other. I did finally get my Echo working, including timers and alarms, on my Netgear C6300, albeit painfully. Below are the steps I had to take, but know I did these once with no success then decided to do a full factory reset and try again. Everything below worked after a factory reset. Unfortunately, this is not the first time I'v had to perform a factory reset to make my new technology work with this router. Anyway, here is what worked for me:
1- Disable port scan and DoS protection (WAN setup)
2- Enable Repond to ping on Internet port (WAN setup)
3- Select port forwarding to always (port forwarding/port triggering)
4- Create the below six custom services (port forwarding/port triggering) <-- I got this list of ports from Amazon
a. 123 (TCP/UDP)
b. 40317 (TCP/UDP)
c. 49317 (TCP/UDP)
d. 33434 (TCP/UDP)
e. 4070 (TCP)
f. 5353 (UDP)
Everything has been stable for a couple of days, but still holding my breath a bit. Good luck to anyone else!
- erin1954Aug 05, 2016Aspirant
Thank you for posting how you corrected your issues! It has allowed me to reconnect my Echo and the timer now also works!
- chewiegoodieJan 09, 2017Aspirant
When you checked the Disable Port Scan and DoS Protection did any of the DoS events still show up in your log?
I am having issues with my Ring doorbell after it has been working for many months just stopped connecting for video and audio but notifications are still working for rings and motion. I tried checking the Disable Port Scan and DoS Protection box but events still show up in my log as if it was still activated.
Thanks,
Chewiegoodie
- johnwloneillJan 25, 2017Aspirant
Hi I'm currently trying to change my ports and everything. This is my second amazon echo and the first one was sent back because they thought it was faulty and after an hour on the phone with Amazon on this second one they told me I need to open up ports. They gave me a list of ports excatly like yours but plus one. How did you set up the ports? What did you use for the IP address? I just want to make sure I'm doing it right because I tried opening the ports but it still is't working. Thank you.
- DarrenMJan 27, 2017Sr. NETGEAR Moderator
Hello Johnwloneill
You use the IP address of the Echo itself you will need to go to the attached devices tab in the settings of the router and it should show the Ip. Then you open the ports for it.
DarrenM
